Did the update jpt fiber laser now all the images are upside down and backwards. I have changed the orientation dots they do nothing can I just roll this back before the update or how do I fix this I can’t afford to have my machine down. Thank you.
What I would do first is do a File./Preferences/Load Prefs Backup and select one of the configuration backups from before you did the update. This should restore your configuration for your machines before things glitched. That SHOULD fix things.
If it does not, the configuration for that is available if you hit F3 on the keyboard, and change things in this area. You’ll need to play around with the toggles to get what’s correct for your machine, as it depends on how that particular machine is configured:
