Upgrade license
Hi,
I purchased an upgrade license for a 130w co2 laser
For days I have been trying everything… even deactivating the license but your server replies that it doesn’t work.
What can I invent to work?
Greetings Alessandro Ornelli
support@lightburnsoftware.com
The fastest and best way to do it is to go directly to this address, as usual they are very quick to answer/help.
Thank you…
HI,
Can you send the link you described?
I couldn’t find the page you pointed me to.
Thanks Alexander
He sent you the support E-Mail address. Send them an E-Mail
address not found
Looking into our systems with the email you use here, I see your key and see that you have support for both GCode and DSP controllers. What do you mean, exactly, when you say “it doesn’t work”?
You will need to create a ‘Device Profile’ for this new 130w system. You can add this using the ‘Find My Laser’ tool or add manually to connect and use this DSP support. Did you do this? What was the result?
Yes, I have experience with software configuration
the problem is that I switched from a diode laser to a co2 laser and with the license upgrade.
Unfortunately when I try to activate this new license the server gives me an error.
Thanks Alessandro
Thanks Alessandro
Go to Help->License Management in Lightburn. What does it show for “Device types enabled”?
Hi,
thanks they replied to me via email
