After the upgrade 1.0 my line and fill, and also fill are not working. line is ok. I have seen on other forums that some other people are having the same problem. is there a fix for this
thanks
Lee
Hey Lee,
please try this:
Good luck and cheers,
Brian
I have enabled $32=1 and tried both fast whitespace scan on and off but still nothing. It burns fine in line mode but nothing if it has âfillâ in the mode.
In fill mode the laser moves as it should but does not fire. In line and fill mode the laser moves as it should but when it comes to draw the line it comes on but not enough to burn.
Okay, letâs try out this one next:
Brian
Itâs set at 1000, this was the setting that i had before the upgrade. Thank you for you help but donât spend too much of your time on this.
I have copied and pasted the support data into an email to lightburn support. I hope it helps.
Thanks
Lee
