Upgrade to galvo licence?
I’m sure this is here somewhere, but it’s not coming up in searches.
My DSP licence expires in 11 days. I also want to upgrade to galvo. Do I have to buy the renewal and the upgrade? Should I wait so that they both expire at the same time, or will they expire separately and will there be a separate cost for each?
Thanks.
You need to get both. It’s in the note under the galvo upgrade window.
Thanks Jeff.
Just to expand on this further. Purchasing the Galvo license will add that functionality into your existing license which would still lose access to updates in 11 days. Adding the Galvo license does not change the expiration date for your updates. If your update ability is expired, you would need to upgrade that at the same time, unless you are running 1.2.x where Galvo was added, as you’d need to update to at least that to be able to use the Galvo functionality.
