Upgrading Ortur Laser Master 2 module?
You seem to be missing something. Should not the 24v (-) and controller (-) be tied together? Otherwise, you have no common between the Laser and the controller for the PWM signal.
Good catch. That diagram was part of a bigger one that included the volt/amp meter, and it showed the grounds tied together further upstream. It was a case of “well, I know they’re tied together”. I’ll get it corrected, thank you for bringing it to my attention.
Overall impressive mod and setup!
Thank you. I think the only thing that’s still original is the frame and stepper motors. I’m taking all the old parts and putting them on a larger custom-built frame, so I can do large format engraving. It can also be a loner, if someone wants to try their hand at laser engraving.
