Upload cut file previously SENT to Ruida?
So, Lightburn and RDworks have a mechanism to SEND a data file down to the controller. Is there any way to RETRIEVE a data file from the controller?
Backstory: I’ve misplaced the flash drive upon which I have saved some work-in-progress, both the .LB files and the SVG etc from which they were created. Until I find that flash drive, or remake the artwork, the only thing I have is those named data files down there in the controller. I sure would sleep better if I could suck them back up the USB cable and into my computer. Is this possible?
Are you able to copy the file from the controller to USB drive in the file menu? Does your controller have the option File->Copy to udisk?
