I have changed it in device settings it was in bottom right corner going backwards now changed it to bottom left and now its backwards on my screen but burning the right way how do i fix this?
so right now everything i work on i have do design backwards?
The machine origin is stored in your files when you save them. So, if you change your machine origin and open an old file, it will be flipped around based upon the origin it was saved with. The best thing is to get your origin correct, and test with a brand new file. Then, when you have everything working correctly, fix your old files that were saved before things were set right.
