Urgent Assistance Needed - Machine Settings Issue
Dear Lightburn Company Team,
I hope this email finds you well. We are currently facing a critical issue with our machine and are in desperate need of your guidance and support to resolve it.
Recently, I made an inadvertent change to the machine settings within the Edit menu, and since then, our machine has been exhibiting erratic behavior and is not responding as expected. This has led to multiple issues arising during our operations, and we are unable to complete crucial tasks.
In an attempt to rectify the situation, I have also tried to perform a factory reset on the device, but unfortunately, this approach has not yielded the desired results.
Given the urgency and severity of the situation, we kindly request your immediate assistance in diagnosing and resolving this problem. Our business operations are greatly hampered, and we cannot afford any further delays.
Please let us know the best course of action to take or if you require any additional information to assist us effectively. Your prompt attention to this matter would be greatly appreciated.
Thank you in advance for your assistance, and we look forward to your swift response.
You might want to email support. You don’t describe what problem you are having.
As many have noted, and as I have experienced in the past, a controller reset is never the right approach. It would be advisable for you to identify the machine manufacturer and model as well as the controller in use. In so doing, you may find another user here or elsewhere on Reddit with the same model who can back up the settings of the machine, provide them to you to be restored. Once that is accomplished, you may not have the same troubles you are now experiencing. If you do, it would require a new post with details regarding the difficulty.
Anytime you modify a configuration, find out how to save the pristine copy first… Edit → Machine Settings → Save works in Lightburn…
There is File → Load prefs backup
Never used it, but it couldn’t hurt at this point… do a save of your current configuration…
Good luck
