USB Copy Failure when image is used
I’m having a problem when trying to upload a file via usb to my Ruida controller. I am able to upload files that have engraving and cutting but if I add an image to the file I get a Copy Failure. Long ago I was able to burn an image so I don’t know what I’m doing wrong. I’m using the same PC that I used last time. Any ideas?
Thanks
Is your controller full? Maybe you need to delete some stuff off it?
I had already deleted all files on the controller. However I did figure out the problem. My USB stick was full. When I saved my RD file in Lightburn everything was normal, no errors, but then I noticed there wasn’t any room left on the stick. Once I created room everything works. Thanks for the reply.
