Continuing the discussion from [USB Drivers for MacBook Air].
(https://forum.lightburnsoftware.com/t/usb-drivers
I have a MacBook Air m2. First I had to buy 2 usb-c to usb-a connectors from Apple because my cheap ones from any where else did not work. Then I installed them still no connection. I then reversed the connectors and finally was able to click on the bottom center where it said Bluetooth and finally listed a new port connection. Then I had to check on the next box on the last laser.
No drivers were needed to be downloaded.
Genmitsu L8. I used the 2 cables that came with the laser which both have usb-A ends. My computer only has 2 usb-c ports. So I had to purchase 2 usb-c to usb-A cables from the Apple Store as my cheaper version did not work. I have a MacBook Air with a M1 chip.
I’m not sure a hub would work as fussy as the connections are.
this is probably the issue
M series macs dont handle 3.0 handshakes well
You need a USBc to USBa 2.0 hub - the 2.0 is important
They are like 10-15$ on amazon.
That will force Mac to connect to your laser via 2.0 and not even try 3.0 usb protocol - which fails silently.
