Use background image as guide only (don't burn it)
I’m working on a design that fits in a non-regularly shaped piece of wood. I took a photo of the wood with rulers around it, so I could import that and resize it to actual size to use as a guide for placement of text and other images.
Is there any way to tell LightBurn to not print that particular image so I can keep it there to use as a guide if I have to edit the project later? I know I can delete it, but I want to keep it just where I positioned so I can keep using it for reference without it being burned.
Disable the “Output” toggle in Cut settings for that layer.
Thank you!
