Use LightBurn instead of Imag-R to engrave on Black Painted Canvas?
Can I use the new version of LightBurn to engrave on black over white painted canvas instead of using a software such as Imag-R first? It will help a lot if I can use LightBurn only. I’m using Ortur LM2 20 W diode laser. I appreciate your feedback. Thanks,
I’m trying to use Imag-r, but haven’t used it enough to give you much help. Images are one of the most difficult, for me.
There are lots of videos on Lightburn and image processing… It is something you have to work at.
Are you setting the layer to ‘passthrough’ when using imag-r for pre-processing.?
Good luck.
I appreciate your quick reply. I have not used Imag-r before and have not engraved on canvas yet. I was asking if it is possible to use LightBurn only without Imag-R. Thank you for your help.
Of course you can… Lightburn has some really great tools and an easy work flow.
Many of us use other ‘tools’ to create things. This site creates finger boxes in a format that not only Lightburn can read, but most other software.
https://festi.info/boxes.py/
It’s much easier than computing all of the parts and drawing it in lightburn.
So you can use external tools to make life easier, but Lightburn is capable of doing most of it if not all.
Good luck
Thank you so much. Your feedback was so helpful. Regards,
