Use of Layers - Significance of 00 layer
Is there any significance of the 00 layer, or can all the layers be used for any type of mode? In particular if I want to do a cut through my material can I use any layer. Also is it necessary to specify the material thickness?
All layers are essentially the same and can be used for any purpose. The only exceptions are the two Tool layers that are assigned to T1 and T2. They are never sent to the laser, have no cut settings, and are meant to be used for design construction and framing purposes.
Thank you.
