CO2 with Ruida controller. When using absolute coordinates things work ok. When I select user origin and there are objects outside of the cut area the origin moves to the extreme perimeter of all the objects.First pic is the cut area with absolute coordinates, second is the same screen only zoomed out to view objects outside of the cut area and set to user origin. Notice where the green dot is in each.
Select only the objects you wish to cut, then enable âCut Selected graphicsâ and âuse selection originââŚ
Do you get an warning from Lightburn when you use absolute coordinates?
Good luck
No warnings with absolute coordinates. Iâve been using only that for years and just started with the other options to check them out recently. I will try selected graphics but why should I have to? I think if things are outside of the defined cut/bed area they should not be considered as usable anyway.
Ok I tried âcut selected graphicsâ and it behaves the same. The green dot is still in the same spot and I still get a warning when trying to frame or cut if âuser originâ or âcurrent positionâ are selected.
Make sure you also toggle âuse selection originâ
That just brings the green dot to the corner of the bed, not the user origin.
Ahhh I take it back. It does move it to the corner of the bed but when graphics are selected it is correct.
With no other graphics outside of the bed area it performs properly without selecting âcut selected graphicsâ or âuse selected originâ. Seems the program could be made to ignore anything outside of the bed area for origin concerns. If something is protruding from the bed area to outside the bed it throws a warning so it must know.
I remember seeing a youtube vid that said it would ignore anything outside the bed. Donât know if that changed in a newer release or what. But it would be nice to have.
There is a toggle switch in General Settings⌠âIgnore out-of-bounds shapes if possibleâ
Yes there is and mine is toggled on so that didnât help the situation. Thanks anyway.
Same here.
Mine will do the whole job, inside or outside the work area⌠Iâd expect this so I donât think itâs a bugâŚ
Mine throws a warning when I try
That
I have wondered how to get around this myself. I havenât seen a âsolutionâ in the conversation, so far, so I am wondering if this is actually a bug.
Keeping drawings outside of the working area is pretty necessary for a number of reasons. But, when you do that, it seems to mess with your âstart fromâ coordinates, as has been described in the post previously.
Basically, I guess Iâm mostly just piling on, and saying âyeah, I have the same issueâ.
Not a solution but rather a work around. Using âCut selected graphicsâ and âUse selection originâ makes it work it seems. I havenât actually tried it on the machine yet but it seems to be viable in the program from what I have seen. Perhaps we will get the âOfficialâ word on this pretty soon!
I tried it yesterday and it did work fine.
I thought maybe @LightBurn would chime in on thisâŚ
The behavior is as designed. When using Absolute Coords, the grid matches the working area of the machine, so itâs trivial for the software to see whatâs outside the work area and not send it.
When using User Origin or Current Position modes, there is no correlation between the grid in LightBurn and the work area of the machine, so we canât trivially discard things that are out of bounds. You have to use âCut Selectedâ and âUse Selection Originâ as youâve found.
