Using a FoxAlien Masuter Pro going everywhere
Have been using this laser for about a year and it does great. I recently hooked up a rotary engraver. I never done anything with it, so I changed all the settings back to original. I have been trying to engrave a plaque and when I frame it, it goes across the bottom then makes 90 and won’t stop at the next corner. I am lost on what the problem is. any help would be greatly appreciated.
This tells me you originally saved the parameters, changed them for the rotary, and then changed them back. Assuming this is correct, did you uncheck the Rotary Enable button in the Rotary Setup window?
If my assumption is wrong, there is a 99.98% chance you did not change all the settings back.
