Using LightBurn on a remote laptop without laser hookup
Which file do I need to run LightBurn on a 2nd laptop so I can design etc without being hooked to my Xtool D1 Pro. I was told it was here at Xtool
Same one as you use on your XTool, just set up a ‘dummy’ device of the same size.
Click on the Devices button in the laser panel on the machine that has your XTool connected. Select the profile and click the Export button.
Transfer that file to your other computer. Then go to Devices again and use the Import button this time.
Now you will have the same profile on each machine. You don’t need to actually connect to the XTool to use that profile.
What is the number of machines this can on total?
