No matter what I do I am unable to get Lightburn to see my laser with Kaspersky installed but LaserGRBL runs fine as does all my other software! Has anyone else come across this and if so do you have a workaround?
I’d generally recommend moving away from Kaspersky!
i use lightburn gcode and kaspersky too and i have no issues.
I am in the UK but well aware of the stand the US has taken against Kaspersky but until told otherwise I will continue using Kaspersky as I have done for the past 7 years without a problem.
But be that as it may I am no nearer finding a solution to the current problem other than disabling Kaspersky and unplugging the internet which is not exactly ideal.
Thank you for your post. I shall continue my search for the cause of the problem but as I said in my reply to fins I do have a workaround of sorts so it is not a total disaster.
