Using Lightburn with Longer Nano Pro 12w
When i first got my Longer nano Pro Lightburn worked great. it is a better software to edit everything in, but lately when i try to burn or even just frame my work it starts in a corner works its way to another corner then goes diagonally across and sits in the third corner laser still on. Switching to Laser burn works even when exporting from Lightburn as SVG to use in Laser Burn but doesnt always let me keep the fill or cut properly.
Any help on this would be greatly appreciated.
Thank you for your time.
Hi Colin,
What has changed since the last time it worked? LightBurn version change?
It looks like there are a few ways to connect to that laser.
Are you connected by USB or Wifi? (If Wifi, can you upload the GCode file from LightBurn to the machine and then start it using LaserBurn?)
Does the job look ok when you preview it in LightBurn?
Is this when starting the job or framing? Which corners? Front left to front right to back left?
Do you see any error or alarm messages in the Console Window? If so, please copy and paste them back to us:
Have you tried restoring your LightBurn settings from an earlier time?
