Using lightburn with snapmaker 2.0
Can’t conect to snap maker 2.0 have been trying for almost 2 months. Can’t even use generated image in lightburn on snapmaker 2.0.I have been reading and following instructions by others on your forum with no success. I have no problem with the program itself just can’t get anything to work on Snapmaker 2.0
Did you try this Snapmaker 2.0 A350 Setup Guide?
What do you mean you cannot connect to your laser?
In the ‘Laser’ window in the bottom right, above the ‘pause’ button it tells you the connection status.
I’ve only seen ‘Ready’ and "Disconnected’. If it’s “Ready”, you should be able to control the machine by jogging the head somewhere.
:slight_smile:
