I’m using WeCreat Vision and I’ve downloaded the latest update for both Vision and lightburn. Initially I was able to use lightburn on the vision for flat projects. However, when I switched to the rotary, it would not move the laser module on the perpendicular axis (get X and Y confused when not looking). I can get it to focus on the spot, but it returns to home position. When I frame, the laser head just moves left and right while the rotary spins the distance. So I tried to outsmart the system by tabbing to the correct starting spot by using the move arrows and set the origin. Then the laser would go to that spot but return right back home. The file on console mode would say job completed.
So I reimported the file to start over and now it won’t do any of that. And after taking out the rotary device to burn a flat project I get the same issue, laser module will not move. So, out of frustration I returned to using the generic Vision archaic program. I need some help.
