I am currently controlling my CNC router using a centrino Acorn 6 with CNC 12 router control software. Currently I am using Generic g code output from millmage core to a thumb drive then I load it into CNC 12. The problem I am having is that millmage does not use the correct g code for manual tool change & tool length setting using a touch off pad. is there a plan to create a g code flavor for Centrino CNC12/Acorn 6?
MillMage has the ability to use Custom GCode for most commands, in the Settings window. You just need to know what code should be.
Welcome @daveh4523, and thank you for reaching out. ![]()
What have you set for your desired tool change and tool length probing in the MillMage ‘Custom G-Code’ settings found here?
For MillMage to generate the G-Code required for this controller, you will need to configure these settings to match what your controller expects for safe Tool Change and Tool Length probing.
