Using rotary on Y-axis (swap) with RDC6445G
Sorry for the delay, it is Christmas crazy round here.
Because my machine was wired for the Y disconnect half the wiring for the U axis was already there.
I got a similar driver to the other two from aliexpress and followed the wiring example from the other two.
This is light weight wiring compared to my cnc machines, the wires I used were much bigger than the factory wires.
As a temporary solution you could decrease the line interval until you don’t have the gaps?
I haven’t tried that yet, but I had thought of it too, after reading a few hours. seems promising! just use lightburn to work around the Ruida. I am kicking myself for not going ahead and having them wiring in another $30 U-axis controller with wiring…
So I’m so busy I have a controller but still haven’t researched the wiring. Anyone what AWG I should use? My laser has pre-made cables with connector types typical of all chinese lasers as far as I can tell.
You need to mention the current draw of the motors to get a reasonable answer.
