I am not sure if this is only a Laptop issue. I cannot get the Style Views to move into the work areas as needed I have been able to do this with my Desktop Computer. I have three laptop computers I prefer to use. When using the laptops, I have to have the different Style Views Spread out all around to use them. I have to use the Widow Command and “Reset to the Default Area” to get ready to engrave a project. This has happened with every laptop I have seen used, I believe. I am now using the latest version of the Software and it is still an issue Version (1.7.01.03)
Not understand what you’re meaning. Post a couple screenshots showing the issue.
These are the pictures from the right hand side of LIghtbur.
OK, now I understand. If your screen resolution is too low, like on many laptops you can use just a single panel instead of stacked. Here is how I have my Macbook set up.
This video should help.
