UV Laser First Pulse Suppression
I was recently gifted a CRS-355-10 based laser engraver and am having some difficulty setting this up in LightBurn.
Whilst the laser functions normally using EZCAD Lite, I must admit having a rather serious aversion against that atrociousness of a software and would thus prefer using LightBurn.
The primary issue I face is the lack of configurability of the (duration of) the First Pulse Suppression/Killer the LMC-Digit-LV4 controller provides and the laser source supports, causing every line to start with significant burnin.
Note that this is not an issue with classic galvo-laser timing.
Is there any way to configure this that I have missed or is there any chance this will get implemented any time soon?
Thank you kindly for your answers!
Best
A photo would be a nice addition.
:grinning_cat:
I don’t have a photo of a marking if that is what you mean, but even at ridiculously high Ton, there is still burnin, which strongly suggest FPS not working correctly.
There is a First Pulse Killer toggle in Device settings window.
I am aware, however these settings don’t seem to make a difference and per the documentation are intended for CO2 lasers, not UV lasers. The only appreciable difference is setting the FPK start power to 100 %, which completely eliminates the output. FPK increment has no observable effect.
