trying to find the magic number for power with the q pulse setting. Ezcad under these settings worked great. Power shows on lighburn 20% but to my understanding uv is pretty much set at one power.
This reads like you are talking about two machines at the same time. There is no Q-pulse in GRBL and no, the diode power can be varied.
I believe you are correct, can’t change the power setting for a UV machine.
Here are some settings from one of the sites.
I don’t have one of these, but I’d hunt around for the manual on the source. It should tell you the values that you need… I don’t have windows, so I haven’t spent any time with EZCad.
On my fiber if you set the frequency to 1, it goes in the CW mode. However the most power is produced at 40kHz.
Good luck
