Hello,
Happy to see that V1 works on snapmaker artisan.
I did a project, all good.
However once the job is done, in the job control, the timer still runs. Not a big deal, just need to press stop.
Cheers.
Hello,
Cheers.
Can you go to Help > Enable Debug Logging, run a short job, then turn it back off and send us the log? It should end up in your Documents folder, called MillMageLog.txt
MillMageLog.txt (163.8 KB) Here you go…
Is this machine Marlin based, or GRBL? (I suspect Marlin because of the M114 queries for positioning). It looks like your controller is not sending the ‘ok’ responses to tell us that it received and ran the last 7 commands of the job it was sent.
After you click stop, the M114 query gets positions back in the correct place, so the controller did run those lines, it just never told us it did, and MillMage sits there patiently waiting for it to tell us it’s done, and it never does.
We found a bug in AMD’s USB drivers a while back that seemed to trigger this behavior. Is your computer an AMD chip?
