Variable text ignores line 10
I want to engrave some names with Variable Text and Lightburn is ignoring line 10 of a CSV:
The names:
Ana Maria
Andrei
Andrés
Arthur
Bianca
Bruno
Carla
Charisse
Cristian
Cosmin
Carla
Darius
Darren
David
Elsa
Emanuel
Just in case you think there might be weird characters:
It should stop at “David”, but stops at “Elsa” instead, ignoring “Cosmin”. If I invert Cosmin and Cristian, it wont engrave Cristian.
The placeholders (there isn’t any other %0 anywhere else, I made sure by selecting everything, this is all what gets selected):
Thanks for your help!
Try adding BOM to the start of the file and see if the behavior changes.
Byte order mark - Wikipedia
I already did that in the begining because I have accents.
In that case review all the text’s Offset value and make sure you’re not simply missing the offset for the 10th entry.
You are right! I created an array of real objects because I had to delete one of them because there was a hole in the plank. The deleted one had the missing offset…
Thank you very much for your answer!
