Variable text max length - not scaling toward center
Hello
Im trying to use the new feature where you can set a max lenght for your text and keep the height-width ratio (Disable Squeeze)
The problem is that the text is scaling toward the top when the Y axis is set to center . The same goes if the Y axis set to top, it’s not scaled correctly
The only time its work is if the Y axis is set to buttom
Help !
Hi Andreas,
Could you clarify which LightBurn Version are you using?
Edit, I was able to replicate.
Is sutle but is there!
Thank you for reporting!
Perfect.
Fingers crossed that it will be fixed in the next update :slight_smile:
Oh and if you could add the option to ignore lowercase so the text will stay in the same porsition Ex. STOP vs. Stop- That would be great :slight_smile:
