Variable text problem
I am attempting to use variable text with a csv file. I have a 3 x 3 array to fill with names from one column. I have advance by set to 1. The software is stuck on the first cell of the excel and isn’t advancing to the next name so my 3 x 3 array has the same name for all 9. Any assistance welcomed.
Fixed it. Restarted light burn. Must have been a bug.
Is it possible that you changed the .csv file with more data after first loading it? In that case you need to reload the file for changes to be reflected.
I did change the data but then reloaded the file but it obviously didn’t like it. I restarted lightburn and that did the trick.
