I use variable text to ‘write’ the cuttings conditions on the material I use.
This has worked well. However, I seem to have a problem with the values used when the Layer Mode is Image.
The attached picture shows two variable text strings, the values seen using Play and the values in the Cut/Layer GUI.
Layer C01 is Mode Image where the variable text shows 100/20/1 for speed, power and passes – however the GUI shows values of 100/50/2. Whatever values I enter into the GUI, the variable text does not alter.
Layer C01 is Mode Line and whatever I enter into the GUI is shown in the variable text.
Note this assumes that p is the number of passes which I believe is undocumented in the relevant web page.
I think my test piece shows that the Image settings do have an effect on what is produced
Is there a problem with the variable text when the Layer is set to Image or am I doing something wrong?
Hello Henry
Could you please tell us which version of LightBurn you are using?
And could you share your LBRN file so we can try to replicate?
Thank you. I am using 1.7.00 (as I am controlling an xTool S1 10w).
Attached is the LRBN2 file. Please let me know if there is anything else you need.
image var text test.lbrn2 (47.9 KB)
I am able to see what you are describing, need to do a few tests.
I think what is happening is the variable text is getting the cut settings of the LINE setting of that C00 not Image.
If you add a shape to C00 as Line, you will see is describing the settings correct
Will get back to you ASAP ![]()
Thank you for sharing your LBRN
Hi Henry
Currently Cut Settings obtain only the Line mode of the layer - not the image mode.
So if C00 is an image, it will query the C00 Line settings even if layer is not present.
There is not - currently - a possibility to change this behavior.
Dev team added this to the TODO list but no ETA for when the improvement can be expected.
Thank you - it is good to know what is happening. It would be great to have this corrected (as well as additions eg kerf as previously requested).
