Variable text - semicolon sign - CSV
Hi all,
Something is going wrong when I am using Variable text from CSV.
  1. CSV
  2. Lightburn
    Why semicolon sign is here – for me big question.
Maybe somebody knows how to avoid it.
If you are seeing β€˜,’ in Excel, that means that you have extraneous characters in the CSV file. Take a look at the CSV file using a text editor, not in Excel or something else. I suspect you will find additional unexpected characters.
If you’re not sure about this then upload the CSV file or a portion of the CSV file here. Rename the file with a .txt extension to be able to upload.
thanks for your support. You are right.
Dependent on your regional settings excel chooses to use the semicolon as a separator in a csv file.
and Lightburn always uses the comma.
How to change Excel CSV delimiter to comma or semicolon (ablebits.com)
