When i create variable text ( serial number) like 0d, it work well if i use grid /array to make several item, but it get stuck to the same number (1) if i just copy and past 0d.
The settings: serial number, current 0, start 1 end 999 advance by 1, auto-advance.
That’s how it works. If you just copy and paste an object, how should LB detect the order of objects? It can only work using the array tools. At least if I understood correctly what you were talking about ![]()
Hello
Thank you for these explanations.
I supposed it can use “reading order” left high corner to right bottom corner.
But it’s ok
