We have 3 Boss Lasers with Ruida controllers and occasionally the first row stops printing and I end up having to refresh the template.
The Current, Start, and End are all correct - I set the Advance By to 12. The file is created by a .NET app and I’ve tried both .csv and .txt file extensions with the same results.
Overview: our mooring tags have a certificate number + a location (A or B) which notes which end of the rope the tag is attached to. In the attached .txt file there are 16 ropes (cert #s) with two tags for each. The LS-1420 fixture holds 12 blanks at a time and starts in the upper right-hand corner, so ‘A’ tags print on the right column and ‘B’ on the left.
When I open Lightburn and press Start, I expect 73890-1-1 A to print first but instead 73890-1-1 B prints in the first slot - it skips the first line of the text file.
If I manually insert a blank line to the top the .txt file it prints as expected starting with ‘A’ but the ‘End’ value shows one extra tag. If I then delete the blank line and reload the .txt file, the ‘A’ tag continues to print first (again as expected.) until a new data file (new order) is created by the app.
We have three plants, Ferndale WA, Lafayette LA, and Barcelona SP, this is currently only happening in Barcelona, but I have seen this behavior intermittently at the other two plants - it clears up if I replace the active .lbrn2 file with a fresh copy.
Based on your description I’m going to guess that what’s happening is that somehow the “Offset” value in the Text toolbar is incremented to 1 instead of 0.
In the file that you’ve attached I can see in fact that it’s set to 1. Make sure all the increments for the text are set to 0 and you should get what you expect.
