Is there a way to make it so you can change %0s in merge/CSV text to the evaluated values in the design space? Basically so it’s editable and looks like what the design space looks like when you hit the “Test” button in the Variable Text window.
There isn’t a way to get it editable yet. If you click ‘Convert to Path’ it will bake the shapes directly from the evaluated text, but I don’t have a way to store the in-between stage yet. It’s planned though.
That figures. I should have tried that. That’s perfect for what I need though. Thanks.
If you export it evaluates first too.
