The Variable text feature is a huge boon, thank you. But I have a problem with the inbuilt browser:
With the Variable text feature, I can not see any files when using the built in file browser, I can see folders but no files. Attached is a screen shot of the same folder view from within lightburn and the same folder from my system file browser clearly showing many csv files.
No matter what I put in file name *.csv *.txt no files show. (including star.star not showing on this forum page correctly)
I can get around it by manually typing in the file name, but seems like it is a bug, I should let you know about.
Using a Linux Mint 19.3 OS and lightburn 9.11.
At present experimenting with cutting wood veneer with a 2.5watt diode laser, good results so far.
