I need to mark a few hundred small tags with unique text, i have the text in a csv file set up properly. I created a jig that holds 9 tags at a time on my laser, the problem is I can’t get lightburn to automatically advance to the next batch, so the first 9 pieces engrave, then when I click next it advances each tag by 1, so 8 of the tags are duplicated, is there any way to auto advance these so the first batch has tags 1-9, next batch has 10-18 etc.?
You need to change how many entries that variable text advances by with each run:
The documentation has a good explanation of how everything works here:
Thanks, that works, I must need more coffee this morning…
