Mac Big Sir 11.5.2, 8-Core Intel Core i9, 64 GB Ram.
I just ran the offending file that crashed with version 1.0.0 and 1.0.1. It worked! Thanks for the update!!!
We’re still getting a few issues reported even with this change, so I’ll likely try tweaking the throttle speed to see if we can get it to be more reliable.
Longer term, we have another option we’re testing that will involve a Raspberry Pi and a file (disk image) from us to act as a relay. This is rock solid so far, 2 to 3 times faster than USB, and would let you connect using WIFI over your home network. We may also be able to extend this to include camera support over the same connection.
Bad news. After three complete jobs, ranging from 90 seconds to 12 minutes per burn, the software errored out gain.
A small 13 second burn would not send to the laser. I could “Frame” it to check the size, and that would work fine. But I couldn’t get it to burn, then it wouldn’t talk to the laser any more.
I’ve uploaded the file for your review. It did burn successfully with version LightBurn 0.9.24, built Wed 2021-04-21 @ 19:47.
Hatcher Wesley.lbrn (20.1 KB)
Hi, I am experiencing the same issues as mentioned in this topic.
I downgraded to the previous version which is fine for me.
I am on macOS Catalina
hello all
i have downgrade to 0,9 , fix 1,0 and 1,0,1 not work for me I’m on m1 mbp bigsur on ruida6445
Hello,
I’ve using macOS Big Sur V11.5.2 / Ruida / USB and updated to V1.0.02 but it’s still not working for me
Thank you
Update: I went back to the previous version and now that one won’t work either. I’m at a compete lost. It worked last Friday and now nothing. I have a big job due tomorrow (8/24) so I’m a lot desperate for help over here.
I was able to get the previous version to work
I removed your support data to keep the thread a little more compact - we don’t actually need it for this, at least not right now. (and it’s still available in the edit history of the message, which we can see, if we do need it later)
Version 1.02 worked for a week on Rudia Mac OS Big Sur. I worked yesterday but not when I turned it on today. rebooted everything and still laser head doesn’t move. I’ve gone back to 9.24
I tried this latest version today on my macbook air m1. Unfortunately it froze so I have reverted back to 9.20.
When will this be released?
I am not understanding this question as worded. LightBurn has provided Grbl-M3 support for a very long time.
If you are asking about the patch, we have released. LightBurn 1.0.01 patch release – LightBurn Software
But you say, “Same issue…” then ask about Grbl-M3. You have Ruida listed in your ‘Machines’ section of your forum profile, which has nothing to do with any flavor of Grbl. Very confusing. What are you after, exactly?
Sorry, I was specifically referencing the new patch. I downloaded the beta and it’s not solving the problem.
We released 1.0.01 patch, so you should try that version, not beta.
You have not shared much again. What OS are you using? How are you connecting? And, what does “same issue” mean, exactly. What is or is not happening?
Now I see you are posting in another thread. Same Issue? If so, please pick one post to report the issue. You are making more work than is required.
Connecting via USB. I’m using Big Sur 11.5.1 and the new beta 1.0.01 patch I found in the forum as well as 1.0.02. When running a file it’s stopping mid stream without a predictable pattern, some jobs run complete. When tracing it may do one leg of a rectangle, maybe two then stop. Very strange. I’ve also tried my other macbook with the same result. Switched to a pc and we’re back running production perfectly.
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
This is unfortunately what we’re seeing with MacOS Big Sur as well. We’re working on a solution that will bypass the driver altogether, but it won’t be a USB connection.
@LightBurn so I have run several times just fine but now all the sudden I am back to the issue I was seeing before. I am still on the 1.0.2 from a few nights back. The counter starts counting up but then the job never actually starts.
Isn’t there two existing solutions / alternatives that already exist?
The root cause of this is Mac OS and the FTDI chips in Ruida controllers (arduinos, lighting controllers etc…) due to Apple’s built-in “FTDI” (USB to UART) drivers that don’t play well with the 3rd party drivers also being installed on the computer.
I don’t have or use a Mac. Has anyone tried uninstalling the FTDI drivers from their Mac to see if this resolves the issue? That is what I am reading as the resolution for some.
Just one more piece of trouble shooting feedback, I can cut lines, but can’t fill images on mac. Sure you realize this but just wanted to get that out here.
