Version 1.2.03 for Ubuntu installs 1.2.02
I have just downloaded V1.2.03 for Linux64, but when I install it, it installs version 1.2.02, not 1.2.03. I’m running Ubuntu 22.04LTS 64 bit.
Same here. Downloaded, installed and tried both the .run and .7z versions. They run the 1.2.02 version. I’m also on Ubuntu 22.04.1 LTS 64 bit.
Same here, I thought there was an issue so I went down a rabbit hole trying to uninstall and reinstall. Lightburn installing version 1.2.02 when running file “LightBurn-Linux64-v1.2.03.run” On my laptop running windows 10 I updated to the 1.2.03 windows version and it shows the correct version number.
This is fixed and there will be an update shortly. We moved a bunch of stuff around internally, and one of the scripts used to build and package files was grabbing old content.
Not wanting to hijack the thread … but in addition to confirming the same issue, I’m also on a separate rabbit trail with Ubuntu 22 and wondering if anyone in this thread is currently using a camera (that’s working) … or even better, that wasn’t working on 22 but you resolved the issue … here’s the thread just in case someone has any info. Thanks!
