Updated to 1.4.05 and noticed that the calculation for job time is now way off. 7 seconds into the job and the completion bar goes to 97%. Also, it seems that there is a change when the job finishes, it used to return to the origin point, but on my diode laser, the head moves forward some and crashes into the front of the laser. Is there a fix for these or a way to turn off the added movement when the job is finished? This just started with this latest update. Seems to move about 180 mm forward, maybe to try and clear the workspace?
Is Return to Finish Position turned on?
I red in the past that after LB version upgrade , all previous settings are lost.
That is why, it is important to save your preferences backup.
And can be restored after the SW upgrade.
You would need to reset all your parameter in LB, I believe for your printer.
Mikey, Yep, return to Finish is ON. I position laser, clear Origin and then Set Origin so it used to return to Origin point before 1.4.05. Must have been a Christmas ghost, reset system and it seems to be okay now. Thanks for the spot to check.
Goes to origin, but job timing is still way off. 3-4 seconds into job and green completion bar is now showing 65 to 95% completed, but the time of the job run seems to be correct.
This is the only part I pay any attention to. I was never impressed with the Windows progress bars either.
