Vertical image size probleme
Hello good afternoon, I hope you can help me. The vertical image when cropping or marking does not have the same dimensions as in the program.
What is the cause?
Do you have rotary enabled? If so, disable and retest.
yes, its disable
Is this a new issue?
Does this occur for all designs?
If so, you may need to calibrate your axes.
Check here for more information:
Machine Settings - LightBurn Software Documentation
