Very confused by lightburn tutorials
I have a ortur lasermaster2 and I downloaded the lightburn software. I watched the lightburn tutorials, but when I start lightburn the screen that comes up isn’t the same as the one shown in the tutorials. Also my laser did auto home without my intervention, so it appears to be connected. All the toolbar buttons are “greyed out” and don’t seem to do anything. I uninstalled lightburn and re-installed it but there was no change. I did create a test file and was able to save it but don’t know how to calibrate my laser or to try and engrave it. Any thoughts or suggestions?
This part of your message is a little confusing - if you’ve been through the setup, and LightBurn has found your machine and set up a device for it, and connected, that should be all the setup required for this machine. Start with something simple, like drawing a circle and pressing the Start button, and you should get movement on the machine and the laser should fire. From there it will be a matter of finding the right speed and power settings for the machine and material you’re working with.
If you haven’t seen it yet, our new documentation is in progress, and is more geared toward new users and might help get you going too: Redirecting...
