Hello
I don’t know if it a compatibility issue,
With my Vigor L7, equipped with a Bx20 (20W)
No matter what I do, the cutting function leaves always “holding tabs”,
I do not want them, I want to cut a whole circle clean.
Any help ?
Hello
Any help ?
Ok I think I undertsand:
We have cutting mode ON or OFF in a settings tab.
I understand that leaving Tabs holding, to breack-up the cut-off design is OK ,
just like holes in a paper that can be removed … a tab … like a Check.
Now my question is:
in cutting mode, we see that the laser shoots points: blinks .
in engraving mode, the laser is continuously on: beam .
If what I understood is right;
In this famous cutting mode, since you are shooting blinks, does that laser shot uses
a 100% of the laser or more than that?
As you know in many applications, a limitation of a device can be boosted by using it only a fraction of a second … or microsecond …at a very high load: 200% for example.
Please these are very important questions, I will not be able to invest 60€ in this great software without these clarifications.
Best regards
Can you take a screenshot of the Cut settings? If I am understanding you correctly then no, the laser light should not be blinking for cutting. Or at least does not need to be.
Yes, I have finally understood:
Perforating mode is about the handling of the material.
no the way the laser is used.
Forgive mostly the translators
I confused meanings in the menus/settings,
mine are in frenchy funny language ![]()
This case seems close to me !
And thank you .
I have deactivated perforation mode.
I am in cutting mode.
I still cant engrave , cut, or make a simple circle …
I don’t know why, I have drawn it directly with the integrated design tools.
Please provide us with a screenshot of your cut settings so we may diagnose the issue ![]()
Your screenshot is still showing ‘perforation mode’ on, switch that off and see if that helps
