I have a file where only part of the layer is engraving. Attached is a screen grab showing the layer and the preview. FWIW, it was drawn in DesignCAD (originally as three layers that have been copied into one and it is the once middle layer that is not showing up) then exported as a DXF. When I did my first test two days ago I exported/engraved only the middle layer and it worked fine. Now it does not show up on the preview and does not engrave. Suggestions?
Hard to tell, but looks like you may have 2 copies of said “middle layer” which would cancel out the fill. Could this be the issue you are seeing? Looks darker on the workspace, indicating 2 copies on top of each other. You can see the effect in the image below.
Thank you. That was it.
