In Settings>Units and Grids>Visual Grid Spacing and Shape Move Increments, LB currently converts the entry for mm into mathematical equivalents when changing to inches, and vice versa.
I would like there to be separate entries for each measurement system so that if I set an increment in inches to 0.25”, when I switch to metric, that does not change to 6.3 mm.
I would like to be able to set unique values to each system instead of having it convert.
Thanks @samgrove. If one looks to the top-right of the forum, there is a menu selection that allows folks to suggest new features or vote for other ideas that have been proposed. We use this input to help prioritize our efforts. ![]()
Please search there first, as not to duplicate an existing suggestion. You can post the link to your suggestion back here to assist in gaining visibility.
