I am testing version 0.9.2.1 many times the software on my windows 10 computer crashes and I have to force the shutdown
You got most of the post, but what Oz needs, you left off. ![]()
A post was merged into an existing topic: Problem with beta 0.9.2.1
Just a note to say that I love the 2 window feature for adjusting picture properties.
Also, thank you for adding English feedback on the focus feature.
Note to Oz.
I see that you are getting a number of comments on the 9.21 version.
Would it make sense to put all the comments regarding the 9.21 release into one thread?
I can help test on Windows 10 or Mac OS
I think I’m just going to release it. So far there have been very few issues raised, and none significant as far as I can tell.
I moved them into their own external threads, so I could keep this one as tidy as possible. It’s fine.
Oz, I have traced the problem a little further.
I have a file folder named “Test”
The file extension .lbn is selected as default.
I type “Test” into the Save AS file name and press Save. The “Test” Folder opens, but does not save the file.
If I type “Test” into the Save As file name again and press Save, It now saves the file. with file extension .lbn in the “Test” Folder; or initially, I must select the .lbn2 file extension and then select the .lbn file extension to save the file with an .lbn file extension in the original folder (not the Test Folder).
This is normal Windows behavior that you are describing.
Thanks for the info.
Happy to give this a go. Mac Catalina (use for design) and Windows 10 to drive laser. Using Neje laser. Currently use Ethernet (via file share) or USB to transfer work.
I would love to be a beta tester. I use a GRBL controller and running Lightburn on three PC’s.
I also use Vectric Aspire on my CNC’s and would like to try some of the new file formats.
I am running Windows 10 64 bit.
Thank you
Rick McCaskill
Rickm1947@aol.com
303-682-0440
Hi ,
i would like to test this version.
Window 10 in a virtual machine in Parallels on a iMac .
Ruida controller and Nova 24 Thunderlaser.
Thanks
Jan
Yes, “frame” and then while Ruida laser was moving - “start” button in Lightburn.
It caused laser to become frozen and stop doing anything until forced restart via switching off/on.
Sorry for misquoting.
buongiorno, vorrei provare pure io a testare nuova versione, ho un ruida 100w co2 70x50 già in possesso di licenza, utilizzato su due pc.
I would like to help!
Got MacOS with a Ruida Laser running. Also do a lot of logos and stuff so interested in the multi-image scanning…
Let me know!
Would love to test it out with my Ruida systems- Windows 10 64 bit release.
Will be checking the Danish translations too.
I started using Lightburn 0.9.21. What struck me is that under Adjust Image, the operation only reacts very slowly. Sometimes it takes several seconds for a controller to react. I’ve tested on a PC and a laptop, the same on both. Ruida Laser, Win 64 on both
I would love to test the new software. I also use it for 2D rendering for my cnc router.
