We’ve changed a lot of ‘under the hood’ stuff in the upcoming release of LightBurn, and things are stable at this point, but I’d like to get a bunch more people to test it and report any issues.
If you’re willing to give it a go, please respond to this thread and state which version you need (Windows 32 or 64, MacOS, Linux) and I’ll PM you a link.
I am specifically looking for:
Users with Ruida, Trocen, or TopWisdom controllers, to test the new connection system
Users who like to run multiple copies of LightBurn, to test the new connection system (should be able to send from any copy now, not just the first one)
Ruida users with dual tubes
Users with GRBL-Mega controllers
Users with jobs containing lots of images like logos, to test the multi-image scanning
If you aren’t on this list it doesn’t mean you can’t help - there are lots of changes that will affect everyone.
The complete list of changes in this new release is below:
- [Oz] Added support for SVG (symbol) tag
- [Oz] Added Arabic, Greek, Danish, Catalan, Traditional Chinese, Korean, and updated all translations
- [Oz] Fixed translation of Art Library
- [Oz] Added START and STATUS commands to UDP command socket
- [Oz] Added shortcuts for Print & Cut
- [Oz] Bugfix: Fill+Line mode on Trocen controllers was missing a command
- [Oz] Bugfix: Save As in Material Library didn’t always work
- [Oz] Bugfix: Connection issue with Arduino-based GRBL boards
- [Oz] PLT import now creates a tiny circle when the file contains zero-length lines (these are point shapes)
- [Oz] Added ‘n’ (Number of passes) to Variable Text for Cut Setting
- [Oz] Added support for Z moves in stored positions manager
- [Oz] Made inner/outer sorting ~40% faster
- [Oz] Bugfix: Locale / Language change on startup could crash ‘SetupOriginMenu’ function
- [AH] Allow forcing constant power mode in the regular Grbl profile
- [Oz] Can now select a specific device if more than one Trocen laser is connected via USB
- [Oz] GRBL - keep checking for pause even after all commands have been send, until all are finished processing
- [Oz] Added an Air column to the cuts/layers list
- [Oz] Bugfix: bounds clamping on new jog was incorrect for Y axis
- [Oz] Added bitmap support to SVG exporter
- [Oz] Bugfix: Exported SVGs will now fill anything exported with Offset Fill
- [Oz] Stop / Start / Pause buttons will not trigger if the display is off
- [Oz] Bugfix: Variable Text now handled correctly when using ‘Start here’ in preview
- [AH] Enable saving in lbrn2 format
- [AH] Prim/Vert caching
- [AH] Remember last used export extension and make default for next time
- [AH] Improve font dropdown performance with large number of installed system fonts
- [Oz] DSP controllers now use temporary connections to the laser (connections no longer held open)
- [Oz] Bugfix: Proper handling of NURBS curve weights in DXF splines
- [AH] Add image caching for smaller save files
- [AH] Bugfix: fix cache error when copy/pasting or importing LightBurn objects
- [AH] Bugfix: restore numeric spin arrows for some locales
- [Oz] DXF exporter now exports circles as CIRCLE objects instead of converting to lines
- [Oz] Images can now be scanned together (only with horizontal scanning angles)
- [JS] Copy Along Path now updates count or distance when the other property is changed
- [Oz] Bugfix: Offset tool could produce strange output if a shape was partially inside an open curve
- [Oz] Added “non scaling” mode for Print & Cut - just does position and orientation
- [Oz] Offset dialog now allows zooming / panning while in use
- [Oz] Added “Adjust Image” (right click or Tools option)
- [Oz] Improved speed of dithering functions by 10% to 20% (better interactivity in Adjust Image window)
- [Oz] “SHX path missing” error now deferred until after splash screen closes (caused issues on MacOS)
- [Oz] Bugfix: bent text in an Art Library would bend inverted if imported into a workspace with a different device origin
- [Oz] Bugfix: stored coordinates editor was showing Y value for the Z as well (stored properly, just shown wrong)
- [Oz] Bugfix: fixed a crash when looking for snap intersections on very dense files when zoomed way back
- [Oz] Added ‘Default’ buttons for Ruida power & speed settings, to use the values stored in the panel
- [Oz] Added ‘Enable Laser 2 controls’ setting for DSPs, so you can enable / disable dual tube controls in the UI
- [Oz] SVG import now supports images with clip paths
- [Oz] Added MacOS-Sur version for Big Sur users
- [Oz] Bugfix: fixed a crash when parsing an SVG path that does not start with a valid move command
The big ones:
I’ve made Trocen and Ruida controllers use temporary connections to the machine - When you do something that involves the laser, the system connects, performs the action, then disconnects, much like the stock vendor software, so no more issues with running multiple copies of LightBurn on a single computer and only having one of them work.
Multiple images can now be scanned in a single pass under the following conditions:
- Not using pass-through
- Horizontal scanning only (image can be at any angle, but scan angle must be 0 or 180)
- Only works with dither / threshold, not grayscale
