Wainlux K8 Homing Fail, Position outside the system, not finding limit switch
Hello Community,
I’m not totally new to lasering, but I’m more familiar with trotec laser engravers from work. I wanted to have my own laser, so I got myself the Wainlux K8 10W machine. I connected it to lightburn. Everything started great, but then i tried to make the camera work with this link: hubcio tech blog | Integrating Wainlux K8 laser engraver with Lightburn
Long Story short, i was not able to find the right IP Adress. I wanted to use the camera because the object I’m about to engrave is round and I want to place my design right in the middle.
After that i tried my luck with the positioning and just wanted to get started. Once i press “START” the following occurs:
Stream wird gestartet
G00 G17 G40 G21 G54
G90
M4
M8
G0 X40Y36
Layer C01
G1 X45Y46S600F60000
G1 X42
G1 X46Y54
G1 X43
G1 X47Y62
G1 X33
G1 X37Y54
G1 X34
G1 X38Y46
G1 X35
G1 X40Y36
G0 X48.281Y34.769
G1 X49.969
G1 X50.781Y33.363
G1 X51.592Y34.769
G1 X53.281
G1 X52.437Y36.231
G1 X53.281Y37.693
G1 X51.592
G1 X50.781Y39.099
G1 X49.969Y37.693
G1 X48.281
G1 X49.125Y36.231
G1 X48.281Y34.769
G0 X55.842Y32.928
G1 X58.502
G1 X59.781Y30.713
G1 X61.059Y32.928
G1 X63.719
G1 X62.389Y35.231
ALARM:1
Harte Grenze ausgelöst. Die Maschinenposition geht wahrscheinlich durch plötzliches und sofortiges Anhalten verloren. Die Rückkehr zur Ausgangsposition wird dringend empfohlen.
Auf oder in der Nähe der Linie 0:
Job angehalten
Stream fertiggestellt in 0:00
[MSG:Reset to continue]
ok
Grbl 1.3a [‘$’ for help]
[MSG:‘$H’|‘$X’ to unlock]
$X
[MSG:Caution: Unlocked]
ok
Without anything physically happening, the Machine tells me that returning to the home is recommended. Once i klicked on “Home” (remember the machine is still in the front left corner) the Laser head hits the casing several times making a strange noise and being followed by the messages below:
$H
ALARM:9
Homing fail. Could not find limit switch within search distance. Defined as 1.5 * max_travel on search and 5 * pulloff on locate phases.
ok
[MSG:Check limits]
$X
ok
So I am not able to engrave at all. I do not know how to set the limits or the homing position. In some blogs i read that it is either recommended to switch hard-limits $20 off, others say on is better. Others say the wiring should be checked, but I got it like this out of the box.
Since I’ve seen it in other occations, the following shows my machine confiq:
$0=3
$1=255
$2=0
$3=0
$4=1
$5=0
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=1
$21=1
$22=1
$23=7
$24=500.000
$25=2500.000
$26=255.000
$27=2.000
$30=1000.000
$31=0.000
$32=1
$100=80.000
$101=80.000
$102=585.000
$103=100.000
$104=100.000
$105=100.000
$110=15000.000
$111=15000.000
$112=1000.000
$113=1000.000
$114=1000.000
$115=1000.000
$120=800.000
$121=800.000
$122=200.000
$123=200.000
$124=200.000
$125=200.000
$130=130.000
$131=130.000
$132=1000.000
$133=300.000
$134=300.000
$135=300.000
It would really be awesome if there is anyone who knows how to handle this problem or these problems.
Thanks in Advance
JJ
First, your machine has homing switches?
If so are they located in front left corner?
Due to this site: Review: WAINLUX K8, A Diode Laser That’s Ready To Work | Hackaday
“The K8 does feature endstop switches at the point of origin, which on this laser, is to the front left of the work area.”
Are “endstop switches” and “homing switches” the same? Does this Information help you?
If you jog the machine to center and press home does it home correctly?
Are you using absolute coordinates?
Does it frame ok?
