" waiting for connection" ortur master 2
The software says “waiting for connection” tried to unplug reset the same story. Only yesterday it worked
Which OS and what version of LightBurn are you using?
You can Shift-Click the ‘Devices’ button in the ‘Laser’ tab to reconnect.
Mira en la ventana “Laser” abajo a la derecha de dispositivos, tienes que seleccionar el puerto de conexión, a mi me pasa continuamente que el programa intenta conectarse por el puerto bluetooth y tengo que seleccionar a mano el puerto USB
Look in the “Laser” window at the bottom right of devices, you have to select the connection port, it happens to me continuously that the program tries to connect through the bluetooth port and I have to select the USB port by hand
