Lightburn keeps saying “waiting for connection” it knows which usb port is plunged into my laser. I can use the port with other devises. I have updated all the drivers, i have even updated my GBRL. Please help, I am at a loss
Can you connect using LaserGRBL?
No, LaserGRBL would not connect either
In the bottom left corner of lb, try changing the com port in the small drop-down menu
Did you check the device manager if you still have a usbserial-device listed?
yes. it shows up in the device manager, it shows up in Lightburn too it just keeps saying “Waiting for connection…”
Then another software might be blocking the port. Is any other tool running?
You can try to toggle the “enable DTR signal” option in device settings as well.
No other devices running. I will try enable DTR signal
