Want to reduce number of passes while already started burning
Hi,
I set to 7 passes but now I see it will be too much and will take forever, problem is already started burning. Can I change the setting and will take it if already started burning? I want to set to 3 only.
At the moment i think that you can’t. All you can do, is stop the job after 3 passes, if you can
there is also another solution, you stop the job, set 3 passes, and restart the job.
If I stop there will be areas deeper than others, I wonder is pausing and change will take effect
i don’t think so, cause i think that the entire gcode has been generated by LB
Thanks, I found some similar situation. For some reason my job crashed on the beginning of 3rd pass, not the best situation but no sot bad.
